Starview 4 the box super usb install problem
  • thornton61
    • 4
    hi
    last night i purchased this box and im new to setting one up.
    i have tried downlaoding the firmware and logo file on to my usb then on to my box via usb.
    i still not reciving any channels after scanning using auto scan.
    on the screen after pressin 1570 i go onto nagravision and type
    5a 01 as my prvider is t******t
    below is a 2 digit code 00
    and below that is a 16 digit code. im assuming the problem is with my codes
    could any one help me with this problem please?
    andrew
  • bugaloo41
    • 1598
    You indicate that you have no channels? That to me suggest that you have not scanned correctly.
    Scanning should be straighforward enough, Go to installation and choose your provide and scan. This should pick up channels for your area and provider. Now:-
    1. Access cas menu by pressing 1570.
    2. The last option should say "key emulation". make sure that is on by pressing the > key on your remote. Now exit back to tv and you box should be fine.
    3. If your key emu is on and you have changed the code press "default key" and exit back to tv. Let it update.
    You should be good to go.
    • thornton61
      • 4
      hi bugaloo
      after pressing 1570 there wasn't a option for key emulation?
      i have got basic channels now but on the other channels films,music etc is keeps saying date being updated.
      is there anything to resolve this?
      much appreciated?
      • satsmo
        • 6397
        It will say keycode try that and follow exactly as bugaloo has said. You need to press menu and then 1570.
        • thornton61
          • 4
          wow great stuff guys everything on now i can watch
          royal rumble
          • bearhemian
            not quiet sure how, but i got it, with help from this, cheers boyos
            • ericbmz
              • Aug 2008
              help
              does any one know how many post you have to make before you can download files because i have a star view pvr and i have got a problem finding soft that actully works and i found one that says works but i cant download it even tosee have dos exctlly wat it dos on the tin help more then welcome
                Just one m8 go here http://www.digital-kaos.co.uk/forums/f2/ tell us about yourself and wait a few minutes till the server updates then you can download. Hope you stick around m8
                • brownsville
                  • Mar 2009
                  • 11
                  Starview 4
                  Can any 1 help new to the game uloading logo at the minute and its been stuck on 100% for 10mins dont know whether to turn box off or leave it already loaded the f/w.
                  • XerXes359
                    thnx this rly helped
                    • ozi
                      • 5
                      help!
                      can some 1 plz help ive just got my starview 4 and im having trouble scanning channels as it gets stuch on 23% also i cant access the hidden menu
                      • reg reed
                        • 4
                        starview box super
                        i have a new starview box super and can anybody help me install it . what software do i need and were will i get it.
                        • khenryashley
                          • 783
                          Welcome to dk m8
                          We encourage you to look around the site and read the threads and you will find all the info you need.
                          The firmware is in the red stickys at the top of the page.
                          Instructions can be found in the download section.
                          Let us know if you need any more help
                          • muzmania
                            no CAS menu?
                            hi,
                            i have the box super and the channels went off so i did the usual with the cas menu but when i typed in the 1570 code in the main menu nothing happened even though it worked previous times when i did it.
                            should i reinstall latest firmware?
                            any ideas????
                            i need aquick reply!!!!!
                            • Carson.
                              • 23
                              Originally posted by muzmania
                              hi,
                              any ideas????
                              the software is already installed you need to go on menu, hit 1570 then switch the key code ON.
