Starview 2 MISSING CHANNELS!!!!
  • aed5l
    • 21
    hi there upon scanning my the box 2 with the latest firmware unable to find mutv and itv2 &3 recieving all setanta channels
    your help will be much appreciated
    thanx
  • billyboy73
    • 37
    try checking the channels that have for example TV100 ,TV101 sometimes they come up on them. Have you re-scanned from the main input or from a splitter ??? try re-scanning from the main source
    • camelv
      • 1202
      did you do a factory default after flashing m8.
      its the stuff we think we know that stops us all from learning
      • miles10
        Missing Channels
        Hey,
        Switched the box on this morning and some of my channels are missing. They display a message saying: scrambled or bad channel - Can somebody advise me how I can resolve?
        • camelv
          • 1202
          has your box been updated with the latest firmware m8
            Originally posted by miles10
            Hey,
            vermin may have moved them m8 try a scan
            • khenryashley
              • 783
              Hey,
              Press menu then 1570 and make sure you emu is turned on.
              While you are in this menu select the default key and press ok as well.
              • miles10
                camelv - The box contains v4.57 Firmware, is this the latest version?
                gmb45 - Not tried the rescan yet - hopefully this works
                khenryashley - The emu is turned on.
                • camelv
                  • 1202
                  miles m8, do a factory default on your box this will take you to the language menu, press ok then the next menu will be installation, key in 1570 on your remote which will take you to your secret menu ,scroll down to set default then press ok on your remote, then set emu to ON.
                  now go back to your installation menu and do an automatic scan,once it has finished select sly sports 1 and leave to update itself.
                  post back if you get stuck.
