i have updated my box but now it wont find any chanels
i got i to work for half an hour but then scrambeld chanel came up and since then it will only work if i mess about with it for about an hour ie re flashing it and re loading my chanels file
but it will only stay on for a minit then says scrambled chanel again
does anyone think it might need the power supply replacing
some one please help as i have been trying to fix it for days and its doing my head in
ps. i know i have posted in other threads but i still havent fixed it
Originally Posted by true red
if it is a sv3 that you are using its not compatable with a channel file because they shift them about so much you will have to do a auto scan after flashing then turn your emu on set default k*y then exit to sly sports 1 and leave to update
to access emu press menu 1570..
i have also tried this but when it is scaning for chanels on the botom of the screen where it shows the bars as it is scaning
it says ok. but on the top half of the screen where it shows you what chanels it has found non come up. i know my cable feed is ok as i got the basic service from virmin and they had to put new feed from the box in the street
can any one help
can any one help
If you're line feeds down Mate , all's you'd get is "no signal" displayed , if your box is finding the channels in the lower section of the scan box , but not storing them in top sections , it sounds like a possible memory problem with it .
