Finding channels but not updating
  • JoeSandles
    • Mar 2009
    • 6
    Hello DK,
    I?m having problems with my SV3. I?ve been reading lots of the posts and have tried a few things with no joy.
    I have gone through the 1570 panel and put in the keys manually, turning emu and keycode on. The receiver (on automatic scan) finds the channels but when I return to S*S1 it stays on ?Updating Data...0%? - I?ve also read that, Ch up and Ch down will set it off, and it does, reaching 70% and crashing back or sometimes 100+% and then going back to 0%.
    I?ve done a factory reset too and turned it off for a while at the back switch. Still no luck.
    I'm sure the box is on 8.04e and the new keys I have since Dec 09.
    Now I?m not PC based so Chatterbox is sadly not a option ? I also didn?t flash the box myself (again don?t work off a pc) but have flashed SV4?s an a number of occasions with no problem.
    Thanks for your time
    J
  • jasbo7
    • 1432
    need to know your provider m8 they might have been updated since then
    • JoeSandles
      • Mar 2009
      • 6
      N**. Others in the Dublin area are not having any problems and I'm on the same keys.
      • jasbo7
        • 1432
        this might sound daft m8 but did you save the keys. you might need to flash it again
        • JoeSandles
          • Mar 2009
          • 6
          Cheers Jasbo
          Yes, I've saved the keys - Been trying it daily since last Thursday (so I go at it fresh).
          As I don't work off a PC the thought of flashing it is a disaster - is the factory reset not enough?
          Perhaps its time to upgrade to the easy of SV4 USB?
          • bigfella
            • 879
            Originally posted by JoeSandles
            Cheers Jasbo
            m8 when u say the keys do u mean the firmware cos it s pretty easy to flash
            • boomer39
              • 2818
              cant understand what you mean about not working off a pc. you must have a pc to be on this forum!!
              YNWA..
              • cactikid
                • 12017
                if u try a set default key to clear first,then enter data on 00 line,recheck and press ok for 4 secs to store,go back to 00 line and use the< or > to change to 01,enter data,recheck,and press ok for 4 secs to store,
                all boxes needed a fix from nov/dec to overcome last problem.
                • JoeSandles
                  • Mar 2009
                  • 6
                  Using a old Mac with none of your fancy RS-232 cable access.
                  Also doesn't allow me download toolbars.
                  • JoeSandles
                    • Mar 2009
                    • 6
                    Thanks, I've tried this alright. The box did go down in December last. I was able to get it working again putting the keys in manually and auto scan. This doesn't seem to work now.
                    • JoeSandles
                      • Mar 2009
                      • 6
                      I've bought a USB serial converter - I'll see if I can get the box to talk to the computer.
                      Thanks for all your help lads.
                      UPDATE: The USB serial converter is male and so is the box. Back to the store.
                      Anyone ever used a Mac to flash a box?
                      • satsmo
                        • 6397
                        Thats your problem you cannot use/flash the firmware with a Mac as its a Windows app.
                        It is possible but you would need to use a Windows emulator, which costs unless you know where to look for it. As I am not a Mac user I have not looked for it, I think I heard there may even be an opensource one floating around.
                        To be honest I would ask a friend or family if I could use their PC as it is the easiest option.
