Hi People.
Just thought for those who may be interested in knowing if they got problems using starview 2.
Firstly if you unsure which box you are using try google images!
Had nothing today so did a factory reset, then make sure Key EMU is on, also you will need to press the " set Default key "
Then do an auto scan on TW, CW & NTL.
Exit to see what happens and if you see the message " Data being updated " then you should be winning.....
Suggest at this point to have switch off your tv and leave updating for around 1 hour.
You should be back in business by 1500%!
Good luck.
Good luck.
