starview 2 keeps going on and off
  • surecare
    • Apr 2009
    • 10
    flashed my starview 2 the box with the 457.00 firmware with logo,scanned all channals ,turn emu on ,soon has u connect to any channel it clears the channel but freezes the channel it goes on to 0 then switch yhe box off and on again every 15 seconds , if i go on to radio it works perfectly it doesnt switch on and off , i hav also tried differnt firmware eg 455,454,802e ect it does same goes off and on. can someone please help ?
  • jckw
    • 760
    wot service provider u using
    we are all learning each day
    • surecare
      • Apr 2009
      • 10
      am in pure ntl
      • jckw
        • 760
        have u turned emu on after you have done factory reset then run it of main cable feed then rescan m8
        • surecare
          • Apr 2009
          • 10
          tried that but no luck
          • jckw
            • 760
            wot firmware worked at first
            • surecare
              • Apr 2009
              • 10
              sorry cant help when i got the box it was already loaded didnt check before i loaded 457
              • jckw
                • 760
                my starview was a starview 1 clone in sv 2 box had to flash with 2.57 clone safe firmware it sorted it out. then check wether clone m8
                Webs.com has been shut down on the 31st of August 2023. Find out what that means for your site and how to move it to another provider.
                • surecare
                  • Apr 2009
                  • 10
                  opened it its original box, will it kill the box if i try clone firmware
                  • jckw
                    • 760
                    if its original box 4.57 should work do u still pay min subscription
                    • surecare
                      • Apr 2009
                      • 10
                      no i dont, like i said it clears the channels ,then it freeze the channel and keeps goin on and off on its own with 0 showing
                      • jckw
                        • 760
                        if you dont pay min sub they can turn signal off at source m8
                        • surecare
                          • Apr 2009
                          • 10
                          true mate but my eurovox works well from the same cabel
                          • jckw
                            • 760
                            look out for camelv he might know more to help m8
