More Starviewv4 Help!
  • ste6106
    • Mar 2009
    • 444
    Hi guys Ive had a read through the sticky and a few threads, just need clarification,
    I have been asked to help with a starview 4 box cos I have been successful at the starview 2. Now the firmware in the sticky, do I just save the file to a usb stick, then plug this stick into the starview box and then using the usb menu download it from the stick, because I cannot convert the bin file on my lappy?
    Once this is done will this mean the navigation menu 1570 will work then so the codes will be able to be enterer?
    Sorry if im covering old ground guys
    Life is a party and parties arent meant to last.
  • ste6106
    • Mar 2009
    • 444
    Originally posted by JoK
    Yes m8 download v1.07f/w for UK and just save to your USB device, then plug into SV and navigate to USB menu and upload.
    Once v1.07 f/w is on there you will be able to open up the CAS 1570, you will not need to enter any codes as this f/w will AU, once v1.07 is installed.
    Menu 1570
    Keycode ON
    Exit back to $ channel and let it update
    Just make sure SV is switched off when inserting/removing USB device.
    JoK
    Ta for that will be doing it Monday, just cos ive sorted a few s/view boxes im deemed an expert, it's you lot giving me the info and for that thanks alot
    • newbie2
      • 8
      Sorry but can someone help me please
      Have a starview 4 usb as well loaded logo which took ages but finally went it. Loaded f/w 1.07 rebooted so sure all ok
      Installed channels menu 1570 does not work, also now the factory reset option required a password to run and 0000 does not work nor anything else logical.
      Sorry for being such a plank.
      • camelv
        • 1202
        just reflash as jok say but just flash with firmware ,make sure your box is off at the back when inserting and removing the usb stick ,
        sounds like you box has not took the firmware m8.
        its the stuff we think we know that stops us all from learning
        • newbie2
          • 8
          Thanks all not my box so will try later and advise.
          • ste6106
            • Mar 2009
            • 444
            Afternoon, fellas, just updated the box and everything fine and dandy just wanting to know do I have to leave the usb stick in the back as when I remove it and turn the S/V on all I get is the logo screen?
            • gazza2008
              only remove ya usb when u turned box off
              otherwise u may ~~~~ the box
              turn ya box off take usb out then turn box bak on
              • ste6106
                • Mar 2009
                • 444
                I did that and when I turned back on the logo screen was on for ages and didnt move, turned it off again put isb syick in and turned back on then it was back???
                • gazza2008
                  reflash ya box with firmware do ya scan turn emu on etc
                  then turn ya box off then take usb out
                  • ste6106
                    • Mar 2009
                    • 444
                    Peachy, were ooking on gas so to speak thanks Gazza and all the folk who have had input, its worked a treat now me mate owes me a good few ales which I would pass on to you all except the last time i tried putting beer down my laptop it broke!!!!!!
                    • gazza2008
                      dont forget our beers as well
                      a crate of stella will do the trick
                        a crate not enough m8 what about the other pts
                        • ste6106
                          • Mar 2009
                          • 444
                          Hey no problemo guys I owe you all at least a crate!
                          • gazza2008
                            thats only 4 me
                            u got the rest as well
                            20 crates should cover it
                            • ste6106
                              • Mar 2009
                              • 444
                              Done! I once won a years supply of beer I may have some spare!!
