Help plesae
  • kampac
    • Apr 2011
    • 23
    Help plesae
    Hi I have starview hd combo firmware f5.21 LDR ver00.21, connected to my sky dish. The problem I am have is this, I can watch a channel for hours on end no freezing, soon as start browsing trough channels lets say after flicking between 5 or 6 channels I get, the scrammed message, then after 15 minutes the channels by magic will come back on. Any ideas it's driving me nuts, thank you
    Looks like you have LNB working intermediates how old is your Sat Disk??
    • kampac
      • Apr 2011
      • 23
      3 mouths old, signal and quality very stable
      • tornado
        • Oct 2008
        • 218
        I tryed all the firmwares on my hd combo and they all play up apart from the I was bored one day which is in the downloads here,u might want to try it.
        • kampac
          • Apr 2011
          • 23
          so you think it's a firmware problem?
          • quavis
            • Aug 2009
            • 117
            is this on th epay channels only or do the free to air channels play up too? what do you do to fix the problem,, reboot?
            • kam
              • Sep 2009
              • 54
              most likey a problem with your sub
              • kampac
                • Apr 2011
                • 23
                payed channels, and yes rebooting does the trick
                • ByteMaster
                  • 203
                  most likely the you know what we cannot talk about that your box is connected to. Some of the cant talk abouts have a system in place that if you channel hop 2 quickly it can appear on their system as possibly a second or third box at the same address connected resulting in you getting a blank screen for a pre- determined length of time.
                  Rebooting yes can get around this but is a pain.
                  Once upon a time it was all about backdoor 0 passwords, now its only about the rsa keys !!!!!!!
                  If this post has helped you........... Don't be shy and hit the Thanks button..
                  • kampac
                    • Apr 2011
                    • 23
                    wish I had the same knowledge as you Byte, all I can say is there is only one starview hd combo in the house
                    • ByteMaster
                      • 203
                      Kampac If its at all possible take your box to a friends house and try it there, if they have a dish and close to tv internet. I had a similar issue to you myself a couple of years ago and it turned out to be a fault in the superhub settings i had from virgin. As far as i can remember it was a setting that had some data packets option that was switched on in the hub itself. The box worked fine everywhere else apart from my own place.
                      If youve tried everything else to no avail i bet its an internet related issue or a bad sub as already mentioned.
