got a starview 2 and keep losing all channels, i have to keep setting default key to get them back should i load the firmware again? thanks in advance.
you should only need to set the default k*y once. it should auto update from there are you leaving it long enough to do it its self . best channel i have found to update quick is sly sports 1..it is hardley a big problem though takes 1min to set default k*y
