starview 3 channels gone
  • chel3sea
    • Mar 2009
    • 41
    anyone had any problems with remaining channels going down in last few days.im on ntl in dublin. cant get terrestials ?
  • cactikid
    • 12017
    did u factory reset and autoscan and emu to on incase of frequency change,remove any splitters or extensions first.
    • chel3sea
      • Mar 2009
      • 41
      will try this later,thanx
      • chel3sea
        • Mar 2009
        • 41
        did as you said,now got nothing! help, help
        steps i took,
        menu-factory setting-password-ok-language,english-provider n"l-autoscan-all failed
        • satsmo
          • 6397
          Is your Dbox working from the same connection?
          • chel3sea
            • Mar 2009
            • 41
            yes,main cable in to a booster,and on to various rooms.D box is getting channels but with a lot of freezing,stuttering etc
            • satsmo
              • 6397
              It's a cable problem then. Check all your connections.
              Try a factory reset and scan again from the direct feed. Make sure you take all splitters and booster out of the equation. Obviously you will only get all the channels on Nagra 1 clearing, but all transponders will scan in.
              • chel3sea
                • Mar 2009
                • 41
                if its a cable problem,how come i can get nick jr,discovery sky sports news,etc in crystal.it only seems to be on the main channels bbc etc?
                • satsmo
                  • 6397
                  Try as I said above first and if it works from the direct feed then you know where your problem is.
