can't pick up any sky programs on s/v 4
  • mark080270
    • Oct 2008
    • 36
    hi after a bit of advise if poss got a s/v 4 for a friend set it up at my house working like a dream but took it to his house sky sports no signal same with sky movies + sky 1 ect so did a factory reset and rescanned and s/v 4 doesn't even pick them up but get sentanta etc confussed any 1 have any idea why i can't pick the sky channels up thx in advance
    try hitting default key and make sure emu is turned on..
    • mark080270
      • Oct 2008
      • 36
      yes it was from a splitter but unplugged the splitter and tried direct feed still the same outcome i got sky premiere but that was the only 1
      • BRASS EAGLE
        • 307
        I WOULD GO WITH jOk & mACA 58'S ADVISE, CHECK THAT YOU HAVE THE RIGHT PROVIDER & CHECK THE FREQUENCY AS ALL IT NEEDS IS TO BE A WEE BIT OUT AND YOU WILL MISS OUT ON CHANNELS,AS I LIVE IN CENTRAL SCOTLAND THERE IS 2 AREAS THAT I CAN SCAN AND THE EDINBURGH ONE WORKS PERFECT, ALSO WHEN YOUR IN THE MENU ,ie THE SECTION WHERE YOU SWITCH ON THE EMU HIT THE DEFAULT KEY,AND THAT SHOULD DO THE TRICK,IF THE BOX JUST KEEPS SAYING THAT IT IS UPDATING THE DATA YOU NEED TO GET THE LATEST api bin file
        • camelv
          • 1202
          also try a factory default then set default and keycode on then scan then leave on sly sports 1 to update
          its the stuff we think we know that stops us all from learning
