can any1 please tell me how to install my firmware for my superbox .from my pc to my box as i dont no how as i am new to all of this cheers workid
help to install my firmware into my superbox
thanks to satsmo,hope he doesnt mind,pasted his tutorial...here it is
u can get the firmware from the red stickys at the top of the page or in the download section
Once you have downloaded the firmware, (place it on your desktop). If it need to be unwrapped use a program like winrar. Once unwrapped you should see a Red arrow on your desktop, click this and then click download, (make sure App file Only is selected). Progress bar will commence from 0% to 100%. When it reaches 100% please wait until it says complete.
Thats it flashed.
Scanning For Channels
As per all Starviews this is quite straight forward. After flashing you will be presented with the installation screen. Just select your language, then your provider and finally autoscan.
After autoscan has completed exit all the way out. Press menu, type 1570 on your remote, (to enter CAS menu), and enable key emu. Exit all the way out and put it on Sly Sports 1 to update.
__________________You will need a null modem cable DB9F to DB9F.
Null modem info
If your pc does not have a serial port you will need a USB to serial port adapter to use in conjunction with the null modem cable.
USB Adapter info
These two cable links are only for reference as they can be purchased
a lot cheaper on fleabay.Last edited by bigfella; 29 June, 2009, 17:27.Comment
