I have Starview 4 Super USB, I have Firmware version 1.10 and i just lost my specialist channels plus other ones. It says 'no signal'. Please help me? I have tried a factory reset and scanned it a few times, with the same outcome...
if they only just gone with no warning i would say its could be vm working in the area and all channels will return when done. if its a firmware problem you can up grade this one Digital Kaos - Downloads - The Box Super USB V1.12 but says do not use on clones
wot channel are u missing, is david one of them? you will need to input manual frequency of 346750, best to delete any channel that you are getting 'no signal' on first. by the way, i'm in leeds, maybe different where you are, but can give it a try.
Reason: update
