PVR Key EMU Menu
  • dell_xps
    • 2558
    #16
    M8 I think you need to flash with the very latest firmware that came out last xmas, then do as your doing then enable the one in the hidden menu, then there is another menu you have to enable below the menu lock.
    edit,
    from an old post of mine
    Forgot to add make sure you turn the key lock on, emu on, and the menu lock if you can be bothered typing in 0000 all the time.
    • DD33
      • 66
      #17
      nahh getting an error message . this is for the New PVR
      Error : Model name does not correct
      Decided to just bin it... had enough ...
      Thanks for trying everyone
      • dell_xps
        • 2558
        #18
        PVR Loader v4.01 Jul 11 2007.exe
        TheBoxPVR_v3105_08Dec2008.bin
        StarViewPVR-21122008.bin
        are the ones you need m8, either bin file will get you up and running, i use the the 8th december one I'm sure.
        • DD33
          • 66
          #19
          thats the one... thank you so much JOK and to all you others that helped... you are legends!
          • DD33
            • 66
            #20
            yes thank you so much.... will put this one down to a learning experience... it was realluy good to see everyone helping... thats what its all about.. I will now be floating around here seeing if I can lend my knowlege in other area's
            Again thank you EVERYONE!
            • reg reed
              • 4
              #21
              help i cant get the s/view box super to work it won't take the gtrom download it keeps saying failed.
                ok m8 when you press download wait a few seconds then turn your box on from the back. it mite take a few goes but it should sort you out..........
                • DD33
                  • 66
                  #23
                  ... here we go
