star view
  • groganalan
    • Mar 2009
    • 37
    star view
    hi can some one help me please i have just done a factory reset loaded all the chanals down but they dont work so i tryed to 1570 in the menu but nothing hapens is there a nother way of turning on the emu and all so do i have to reload the firmware and if so what is the lates one out thanks alan
  • martin-f
    • 535
    more info please m8 what s/v do you have what firmware do you have on the box what is your area
    if you have parental lock on try 1668
    • groganalan
      • Mar 2009
      • 37
      hi need to turn on the emu ive put in 1570 but it wont work am i doing some thing rong
      • mo.p
        • 298
        hi m8 just check if all the numbers work on your remoute my m8 had same problem and one number on hes remote did not work
        • groganalan
          • Mar 2009
          • 37
          hi its a new remoute and all the numbers work
          • martin-f
            • 535
            did you read my post and tryed 1668
            • DESSERTDOG
              • 493
              If its the Sv5
              Follow this:
              1. Plug in the box and connect the cables
              2.Format a usb stick in pc to fat32
              3.Copy the firmware onto the stick.
              4 Switch your box off completely and insert the usb in the rear socket.
              5.Switch on the box wait for it to boot up.
              6.Press menu and scroll to usb press ok
              7.The firmware should start to transfer from the usb to the box.
              8.Once this has done hit menu and key in 1570 with the remote.
              this will bring up the secret menu hi light keycode and change it to on.
              9.You should now be set to scan go into menu and select installation,choose automatic scan press ok then choose your provider hit ok again.
              You should now get all channels your after.
              If by any chance you dont get the channels try a different provider.
              If i have helped you please dont post Thanks just use the Thanks button
              • groganalan
                • Mar 2009
                • 37
                hi i have the starview box ver 4.00e-E i go to menu and try to put 1570 in but nothing hapens i just cant get into the secret menu to put the emu on and the firmware is 0060918-258 26012027
                • smoggy
                  • Apr 2009
                  • 12809
                  does your box say TheBox in the top left hand corner
                  if it does the latest firmware is v 4.57 and you can get it here http://www.digital-kaos.co.uk/forums...-loader-18314/
                  • groganalan
                    • Mar 2009
                    • 37
                    no it ses star view in big letters top right of box
                      think thats a s/v 1 m8...
                      • smoggy
                        • Apr 2009
                        • 12809
                        Yes as maca58 says thats a SV 1 model
                        you can get the firmware here Digital Kaos - Downloads - Starview 1 UK AU Fix v1.5
                        if your not sure if your box is genuine put on the clonesafe version cryptstar v1.5 core 257 as this is ok for clones and genuine boxes
                        • groganalan
                          • Mar 2009
                          • 37
                          if i put the new firmware will i beable to get into the menu with 1570 and turn the emu on
                            yes you will m8. all will be fine..
                            • groganalan
                              • Mar 2009
                              • 37
                              thanks maca you are the dogs nuts
