Starview 4 & 5
  • NixxxE
    • 78
    Starview 4 & 5
    What is the difference, Im new to this and debating in which one to get.
    Also which is best in all the boxes out there , dreambox, starview, eurovox
    What is the best/and differences?
    Nixk
  • DESSERTDOG
    • 493
    This question has been asked about 4 times that i can recall m8 please have a read and it saves members repeating there posts to reply to the same question time and time again m8
    If i have helped you please dont post Thanks just use the Thanks button
    • NixxxE
      • 78
      ok mate, ill have a quick search
      • NixxxE
        • 78
        I cant seem to find anything will someone point me in the right direction
        • DESSERTDOG
          • 493
          try the stickys
          • bigfella
            • 879
            m8 ,i dont think they r sellin s v 4 any mores as lots of clones came out so they put a secruity chip in the s v 5 to prevent the copies...both r flashed with a usb stick..makin it easier as long as u remember to turn the box off when u either insert or remove the stick as theres a danger u ll brick the box( knacker it),,,u can also record ur progs n films on the sv 4 n sv 5.....with regards to which is the best box i cant help i only have starviews but if u read thro the threads on here and the othe other boxes u ll get a better idea ,,hope this helps ..if u get stuck post a thread theres lots of good peeps willin to help
            • NixxxE
              • 78
              Cheers are they easy to set up the Starviws? i seen a sv 4 on ebay
              THE NEW Starview 4 The Box Super USB - 100% GENUINE on eBay (end time 27-Nov-09 18:15:23 GMT)
              • boomer39
                • 2818
                easy to so long a you know what you are doing. all help is here.as to what is the best box, what tv, car, radio, mobile etc do you have? personal choice.. luck, whatever.
                YNWA..
                • bigfella
                  • 879
                  m8 i wouldnt buy one from e bay ...wizard satelites sell geniune boxes....there s instructions/tutorials on here how to flash the boxes..they r pretty easy to do
                  • NixxxE
                    • 78
                    Ta,
                    Ive got a question, how do you plug the box in, do you plug the cable in that normally plugs into your modem?
                    also can you plug more than one box in, and watch different channels?
                    • bigfella
                      • 879
                      Ta,
                      you plug your box into the live virgin cable feed....the same one u plug ur virgin supplied set top box into .....or u can plug it into the cable your virgin modem is plugged into.....u can buy splitters and have ur modem and ur sv box plugged into the same feed if u need to.......i dont understand the second part of ur question...watch diff channels???but u can have a box in one room ,put a splitter on the virgin cable feed and run some cable to another room if u want ...or u can buy av senders and not go to the fuss of runnin cables...hope this helps
                      • NixxxE
                        • 78
                        I mean if you split the cable 3 ways, 1 for modem, then the other 2 for 1 box in one room and another box in another room, will each box be able to watch different channels at same time or will you both have to watch same channel?
                        • bigfella
                          • 879
                          no u can watch different channels on each box if u do it like that
                          • NixxxE
                            • 78
                            Where can I buy a 3 way splitter?
                            • xant14
                              • 2062
                              fleabay
                              ebay.. 3 way Cable splitter Sky TV NTL Dbox Satellite+4 f plug on eBay (end time 10-Nov-09 19:22:47 GMT)
                              ?3.58 You might get one cheaper
