starview box problem
  • wayne5102
    • 18
    Hi again can anybody help I have a very strange ongoing problem which I have tried allsorts to remedy my starview box which i believe is sb1 does not allow me to access some channels namely espn,sky sports 1 sky family sky sports news and a few others without changing keys then i have to change the keys again for the other channels any ideas I have loaded the latest firmware.
  • smoggy
    • Apr 2009
    • 12771
    reading your other threads you seem to go off at a tangent and start another thread without solving the one you started.
    by your other posts it appears you have the starview 1
    first off your best bet is to flash your box with the latest firmware use the clonesafe version cryptstar v1.5 core 257 version and comeback if you need anymore help
    firmware here Digital Kaos - Downloads - Starview 1 UK AU Fix v1.5
    loader here Digital Kaos - Downloads - GTRom v 4.00
    • wayne5102
      • 18
      Yes that is somewhat true though not completely I start another thread only because I do not receive a response after some time has elapsed,also not really off on a tangent when the problem is the same.
      • Tezza
        • 42
        lost channels
        if you loose specific channels ,they usually are still listed ,goto that channel ,then goto menau installation ,manual scan ,ensure u have the same freq as channel not working hit scan and u should pick em back up.
        • smoggy
          • Apr 2009
          • 12771
          the trouble with starting another thread is people go over the same ground and finish up wasting yours and their time, far better to stick with the same one even if you have to re-ask/bump it back into contention
          if you have the latest firmware on your box you shouldn't have to mess around with k*ys
          is your box flashed with the above firmware in post 2
