Starview 5 the BoxII set up
  • sas1264
    Hi, can anybody help. Just bought my 1st unit, starview 5 the boxII. I've set the unit up and run the automatic install. All i get is the basic 5 channels and a few freeview channels. Do i need to flash the unit? and if so how do i go about it.
  • larryoke
    • 404
    Menu > ignore the screen & press 1 5 7 0 > turn keycode on > set default > exit to ssp 1 and leave to update > enjoy
    (while it lasts)
    • DESSERTDOG
      • 493
      Or you could do what others do and download the Tut i posted in the downloads section
      If i have helped you please dont post Thanks just use the Thanks button
      • RidgeyDidge
        Hey DD - looked everywhere, I'm a dill - can you point me to the link for the download.....
        the Dunce
        • smoggy
          • Apr 2009
          • 12808
          the Dunce
          the tut is here and don't forget to thank DD for taking time out to help you
          Digital Kaos - Downloads - SV5 tut
          • sammyfish
            thanks for that, glad there are people like you you who can help
            • RidgeyDidge
              thanks folks, mightily appreciated!
              • dringy999
                thanks mate
                • saji1989
                  • 4
                  starview set up
                  i've tried the 1570 code etc however it is making no difference and i can't seem to access the premium channels on the box, currently i just have the free to air channels. could any1 help
                  (while it lasts)
                  • wong
                    • 9
                    make sure you have put the software on the box first m8,then just do as follows
                    press menu
                    press 1570
                    then a pop up screen pops up
                    switch key emu to on and then set default key
                    exit exit exit go to any pay channel and bingo au in 30 secs.
                    • nbrown
                      just got starview 5 box & help to set up. restored factory settings & did the automatic scan. Not getting most channels eg sky sports. can anyone talk me through how to get this thing working!!!
                      • saji1989
                        • 4
                        starview 5
                        i have tried everything with the starview 5 usb. received the box, set it up, copied latest firmare on to the box did format usb to fat32. copied over to starview box. did the start up with the reboot etc, pressed 1570 turned on the keycode, however still no luck in getting any of the channels, still the free to air channels no sky sky sports etc.
                        would appreciate some help
                        press menu
                        press 1570
                        • saji1989
                          • 4
                          hi there appreciate the help it worked great all the channels are working. any idea as to how i can find sky box office on the new starview 5 box, cheers
                          • mark8393
                            • 2305
                            what event are you after, eg boxing, these will come up on 1700 most times.
                            • DESSERTDOG
                              • 493
                              Try up around the 3000 should be in there m8
