Can't transfer starview 5 file from usb stick. help please
  • bigmac09
    • 13
    I'm following instructions on the tut and its not working! Can someone help me out? I have the firmware on my usb but it isnt transfering on the box, and i cant get the secret menu up when i type the numbers.
  • mollydem
    • 18
    clear everything from your usb stick downlaod fat32 to your pc
    then copy it to your usb stick then reload the firmware it will then transfer to your box
    • bigmac09
      • 13
      Do you mean format the usb to fat32? already done that ... :/
      • bigmac09
        • 13
        Would someone be willing to ring me or me ring them to talk me through stage by stage? I really am that shocking with technology. UK Landline ... I would be really grateful .. Im wanting to watch the footie!
        • mollydem
          • 18
          did you empty the usb before you put fat 32 on i had same problem until i did that and then reloaded software
          • bigmac09
            • 13
            Okay im getting somewhere.... everything is done how it should be. Keycode is on etc .... but when i scan for channels i get nothing ... not even bbc1!! :/
            • bigmac09
              • 13
              Done it! Thanks guys!! legends!
              • bigmac09
                • 13
                ahhh hold the phone ... lots of channels have dollar signs beside it ... ?
                • bigmac09
                  • 13
                  How do I get on the channels with the $ signs beside them?
                  • bigmac09
                    • 13
                    Originally posted by JoK
                    Dont worry it will be like that, so long as your Keycode is ON and hit the set default key, them channels will come to life
                    JoK
                    keycode is on ... what do you mean "set default" key?
                    • mollydem
                      • 18
                      have you checked you have the right keys on your nagravision goto menu and then key in 1570 to get cas system make sure your keycode is set to on then go up to set default key and press the ok button to save then exit to sky sports one
                      • Dreamer
                        • 2020
                        as mollydem says above. It's time to enter the menu and set the keycode to on. should be in that guide you refered to earlier
                        The Falkirk Wheel.sigpic The only rotating boat lift of its kind in the world
                        • bigmac09
                          • 13
                          fantastic!! legends!!
                          • Dreamer
                            • 2020
                            Is that you all sorted then??
                            Told you the guys are really helpful
                            • bigmac09
                              • 13
                              yeah all sorted! the guys are great! can someone give me a shout if there is something to turn off audio commentary on sky programs!!??
