All channels have gone off
  • jimmy9434
    • 8
    I only updated the codes a few weeks ago - but I brought it from Leeds and now Im near Norwich.
    It is:
    The Box Super
    Ex C&W (now Virgin)
    I have to manually update it.
    Where would i get the new codes from? Hopefully not breaking any forum rules here. If I am then tell me - thanks all!
    here you go m8 BigMAQ Toolbar Download why not update your box all fixes can be found here at dk m8..
    • jimmy9434
      • 8
      Is the the chatterbox thing?
      I have downloaded that but I need a wire to up load my box. Or am I wrong? I am thinking of buying the box but will the code be on there to manually update?
        you need a rs232 null modem cable to update your box 9pin Serial Null Modem Female DB9F to DB9F RS232 Cable on eBay (end time 30-Nov-09 11:54:24 GMT)
        once you have updated you dont need keys anymore m8
        • jimmy9434
          • 8
          I put a bid in - is ?2.99 the going rate? Is it you selling them?
          When I get one of those is it easy to do?
          • cgscott
            • 3513
            Get 1 for a quid 50.
            http://cgi.ebay.co.uk/Serial-Null-Mo...item20ad8dd8f2
            Patience is a virtue.
              no m8 im not selling them i was just showing you what you need. and yes they are easy to update plenty of people here to help you..
              • portbhoy
                • 717
                You need to factory reset it and rescan iy mate you've moved area so the transponders frequencies will probably not work there, bung in your codes again bear in mind these may be different aswell could be telewest instead of ntl or vice versa. But updating the box is always the best way to go
                • cactikid
                  • 12017
                  and if you are flashing your box do you have a pc with serial port and xp.
                  • jimmy9434
                    • 8
                    Ive got
                    Windows Vista - and look like i only have a female port but would be able to use a pc with the correct ports I think. What difference will the type of windows make and can i get a female to male changer??
                    • jimmy9434
                      • 8
                      Ive
                      tried updating the box - then a few hours later it blocked. I put the codes in since i moved down - so will try reset it after top gear.
                      • cactikid
                        • 12017
                        windows vista you might have problems,get a pc with xp and serial port much handier.
                        • jimmy9434
                          • 8
                          How often
                          would you need to connect it to re flash it?
                          • cgscott
                            • 3513
                            Unless you got a magic wand mate.
                            Yeah go down the null modem route.
                            • jimmy9434
                              • 8
                              I meant how often does it need doing
