Starview 6 usb LAN
  • Scaldy
    • Feb 2010
    #46
    If I get a SV6 (Dublin) will it need to be permanently plugged into the router to work?
    • psats
      • 823
      #47
      Yes...............
      • tmad
        • Feb 2010
        Does it work for both cable and sat?
        • alex123
          • 832
          #49
          its a cable receiver
          • jackoooh
            • 5
            #50
            a cable +terrestial receiver
            • unadkat
              • 340
              #51
              Originally posted by portbhoy
              Providing the proposed server doesn't go down after a month
              secondly whats the guarantee that the servers wil provide enough bandwidth so that you dont get any Freezes on the channels
              Also how mny channels are gonna be available?
              • alex123
                • 832
                #52
                as with any dodgy box there will be no guarentees a server can go down anytime
                it will have all channels not sure about ~~~~
                its a cable and sat box not DT
                but nobody has to buy this box if they dont want to to
                seems if you rubbish this box you get thanks
                but time will tell if its any good or not
                alex
                • cactikid
                  • 12017
                  #53
                  same as providers listings i would have thought,i would suggest to read up about all info on these new boxes first before you buy.
                  • jackoooh
                    • 5
                    #54
                    i think you need at leat 3mb to mantain a descent quality
                    • alex123
                      • 832
                      #55
                      its not an ip box 1mb is plenty but more the merrier
                      • portbhoy
                        • 717
                        #56
                        Keep your Dreams, Dboxes itgates and other linux boxes if theres a server for starpoo then there will be for other boxes aswell
                        • smirnoff_rules
                          • 8603
                          #57
                          still cheaper than yearly sub to the big boys like sly etc.
                          u will still have to pay someone a monthly charge .. bet its going to be 20 a month to at the start .. l think vm will be working overtime to pull these servers ..but time will tell
                          if your going down this root l look around for dm 500c as there cheap and will have lots more support than these ..
                          but sat is the way to go lads
                          • unadkat
                            • 340
                            #58
                            I totally agree!!!!
                            forget the starviews and eurovox and stick to linux.
                            • mark8393
                              • 2305
                              #59
                              I totally agree!!!!
                              all very well, but have linux boxes a fix yet, think answers no. once they have then we could say stick to linux, but starview is the first and the rest will just copy.
                              its seems like being on satkings here, knock every box apart from their own. in the end starview and eurovox are simple to setup, which is what people want, probably 60 to 70% of people would stuggle with a linux box, they just want something to more or less plug and play.
                              basically all boxes do the same and have their own place in the market.
                              • smirnoff_rules
                                • 8603
                                #60
                                with the on set of c/s dreambox's will be even greater . the pli image thats on the box is all u will need as the cccam is already on it , u will only have to edit cfg file and scan .
