Hi just put starview hd combo+0128 and knightrider hd combo +0212 on my box ,but wot do do next to get all my channels working ,sorry im new at this can you help
starview hd combo +
here you go
Starview HD Combo LAN & NON LAN STBs
Non LAN, (No ethernet port), Combo Serial latest firmware http://www.digital-kaos.co.uk/forums...al-model-1116/
The NON LAN, serial only boxes were the first 500 batch that were released.
CAPABLE OF RECEIVING SATELLITE AND CABLE TRANSMISSIONS SIMULTANEOUSLY
INDEPENDENT SATELLITE AND CABLE HD TUNERS
EMBEDDED TWIN CI SLOT
EMBEDDED CARD READER
2 X USB PORTS
PVR READY VIA BOTH USB PORTS
Supports MPEG-2, MPEG-4 H.264 and fully DVB Compliant
Diseqc 1.0,1.1,1.2 and USALS
Aspect ratio adjustment 4:3 (16/9 crop) 4:3 (16/9 letterbox) 16:9 (4/3 pillar box)
User friendly OSD and Operation
Total 8000 Programmable Channels
Multi Language audio support & Multi-Language Menu Text Support
Favorite Channel Selection
parental guide and rating control
EPG (provider Electronic Program Guide) Inc on screen channel info
On-screen Display with 65,356 color
Blind Scan (powerscan) and powerful EPG
8psk Turbo FEC Option
Zoom function in pause
Dolby Digital Bitstream out through S/pdif (Optical and coaxal)
selectable output for 1080i,720p,480p and 480i format
Multiple video outputs HDMI 1.1, Component (YPbPr) Composite
USB 2 Host (access to HDD, USB memory, Others ect 2 x ports onboard
Upgrade software and channel list via usb2.0 and rs 232
MP3 file play by usb2.0
Recorded file play on PC
Reservation recording via EPG
I have not tried this box out yet, but would be interested to see how others will fair out with it.
I will sticky it for now.
To Flash Box:
Load grooverider file on to your usb memory stick, make sure power is off on machine.
Insert the memory stick into the front usb socket underneath the front flap.
Turn the HD Combo on.
From the main menu go to Utility and then press the right arrow button and select usb from the right hand side, you will see the grooverider file press ok on it and make sure to select SW+ALL DATA UPDATE.. the machine will update and restart (don't pull your memory stick out until the machine has fully started up).
MAKE SURE YOU LOAD THE GROOVERIDER FILE FIRST THEN THE BOOT FILE FOLLOWING THE INFORMATION BELOW
How to Upgrade inc new boot file.
1) File name GrooveRider_HD_Combo_F3.50_1118.uad upgrade with S/W + All Data Upgrade first.
2) Then Upgrade again withBoot_V0021 ( type : sw upgrade )
3) Power on/off at the back and then factory re-set
Check your system information says LDR:Ver 00.21
You now need to scan your channels, so go to installation press the right arrow button again and go down to AUTO CABLE SEARCH all you need to change here is the symbol rate.
The symbol rate determines your area for example nt* is 6887, the other 6952 are for telewe*t and EXc&w.
When you have selected your area go to start scan.
Once the scan has finished go to menu then highlight accessory and on the remote press the numbers "8989" you will then see
"keyedit" appear on the right hand side, go to it and press ok and just check that auto update is on if its off just turn it on.
then go to to your channels by exiting the menu and pressing ok.. Select a non FTA channel and leave it until a picture appears
PLEASE NOTE IT CAN TAKE UP TO 5 MINUTES TO UPDATE -
Then mark8983 has given you the wrong info thats for the non lan box
Read the second post here
and here is the other details you require
00012 643000 6887Last edited by Fergal; 19 February, 2010, 20:44.Comment
right info was given, as poster said software was loaded, so info was there for scan.Then mark8983 has given you the wrong info thats for the non lan box
00012 643000 6887Comment
Maybe so but all the rest of the info was for the non lan box which could have confused the member or others looking in thats why i pointed out the correct info in the sticky just incase they decided to reflash it aswell.Last edited by Fergal; 20 February, 2010, 00:07.Comment
sorry its ok ,i did a scan but no channels this is install list
frequency start 306
end 758
step value 8Mz
symbol rate 6887 or 6952 or 6875
Qam modulation 64Qam
scan mode free+scramble
and you gave me some numbers ,not sure wot to do with them 00012 643000 6887
and wot is aFTA channel cheersLast edited by robbo100; 20 February, 2010, 11:47.Comment
