just bought HD combo ?
  • mrmarr
    • 208
    iv had the super usb 4 for a year and thought id upgrade my box to the HD version, well i ordered 2 days ago -i ordered the non lan but got 1 with a lan ?)
    i did a bit of reading here before buying and have read of problems with the lan HD combo ?
    im in uk and am not sure wether to attempt this box or send it back for the non lan ?
    which box do you guys recomend and where do i start
    thanks in advance
  • unadkat
    • 340
    thanks in advance
    LAN box is recommened.
    • mrmarr
      • 208
      thanks unadkat
      im just gona do it now then
      thanks again
      • mrmarr
        • 208
        well i guess im in need of a bit of help
        i have set the HD box up attached the cable line to cable in and put GrooveRider HD Combo + 0122.ua on my usb but it gets to 30% and fails what am i doing wrong
        • mark8393
          • 2305
          load the older software, and then load the newer one, thats seems to be the answer from other users.
          • mrmarr
            • 208
            iv tried 0122-0128-0212
            i will try some older 1,s
            thanks pal
            i notice that the HD combo has a smartcard slot is this going to help with this nagra3 stuff im reading about ?
            • mrmarr
              • 208
              does any1 know the "symbol rate" code for west yorkshire
              because i got it flashed using GrooveRider_HD_Combo_+_1214.uad but i cannot find any channels - but all i have tried yet is 6952 + 6887 ?????????????????
              As per the instructions in downloads load Starveiw HD Combo_+_0128.UAD File first and then the latest firmware. Both found here http://www.digital-kaos.co.uk/forums...firmware-1115/ However depends on what part of West Yorkshire you reside in as it may have migrated to N3.
              • Babyface786
                • 27
                first of all there was only 500 non lan boxes made, now they only produce lan boxes.
                not sure but think the 1214 is the FTA only fw, there has been a few released since then..latest is 0212.
                http://gifts.freebiejeebies.co.uk
                • satsmo
                  • 6397
                  As per the instructions in downloads load Starveiw HD Combo_+_0128.UAD File first and then the latest firmware. Both found here Digital Kaos - Downloads - Feb 09 Latest Starview Combo LAN Firmware
                  • mrmarr
                    • 208
                    i got it working for a few hours but then all the channels dissapeared ?
                    no signal ???
                    dam i shud never have bought this buggy box
                    • pongo snodgrass
                      • 178
                      no they are not FTA fw...you get all channels with them....they are coming out out with a new fw every few weeks it seems like...yet they dont tell you what it fixes or what improvements , if any , have been made..like i said before, ive tried every single fw for this box..all have same problems...freezing and glitching...
                      • unadkat
                        • 340
                        why doesnt that suprise me
                        when u say there is glitching and so on... could you explain a bit more please and you setup as well
                        • mrmarr
                          • 208
                          WELL THE CHANNELS ARE THERE 1 MINUTE AND GONE THE NEXT ALSO SOME CHANNELS HAVE DECIDED TO BECOME SCRAMBLED AGAIN (just noticed the caps lock)
                          but at least the kids shows are ok (phew) mornings would kill if that went
                          • phattang89
                            sats chanels or cabble chanels ? matte
                            • unadkat
                              • 340
                              it has to be cable channels... seeing as the box does not function exactly to well on sat side ....
                              Starpoo team are a genius on there marketing skills.
