Starview the box usb 11 problems !
  • boxer44
    • 7
    Hi When i scan on my box i cant find any channels also no emu in the 1570 menu !. When i try flashing new firmware it comes up with it is not a file of this ird. Any ideas ?
  • satsmo
    • 6397
    Which firmware version are you using, as it looks like you are not choosing the correct one.
    • boxer44
      • 7
      The box locked with the dreaded 8888 code so i sent it of to a chap in Birmingham, who got the menu back up, i keep on e mailing him but all he tells me to is to turn the emu on ! which cant be found, So iam not sure which firmware he has loaded.
      • cactikid
        • 12017
        menu-system info ok-v????
        • boxer44
          • 7
          Menu fine just no emu !
          • cactikid
            • 12017
            need to know what firmware is on box,do as i said and post again.
            • boxer44
              • 7
              TheboxSuperUSB2_v2.05.091023
              • smoggy
                • Apr 2009
                • 12771
                it has the latest firmware on but there have been bad reports with this firmware causing problems, I would reflash the box with the V2.03 firmware and see what happens
                firmware here Digital Kaos - Downloads - TheboxSuperUSB2_v2.03.20090923.BIN
                but read this tut first Digital Kaos - Downloads - SV5 tut
                ALWAYS switch off the box before inserting or removing the usb stick
                • cactikid
                  • 12017
                  looking at first post are you scanning correct provider,and was there a factory reset/default done first.i see one other person got 2.05 to work on second lazy scan.
