Starview 5 Dead
  • vtorres
    • Sep 2009
    • 159
    Starview 5 Dead
    I had just come home and my dad had told me that the normal channels are working fine but the pay channels werent, so i went through the normal process of factory reset n re scan etc but as soon as i put in the password for the reset the unit turned off and now it wont turn back on no lights no nothing its dead is their any fix ? is the problem in the box or from the power lead please help.
  • Dreamer
    • 2020
    I take it you have already tried replacing the fuse in the plug and checking that the socket you used is still ok??
    The Falkirk Wheel.sigpic The only rotating boat lift of its kind in the world
    • vtorres
      • Sep 2009
      • 159
      The socket is fine, and have not tried replacing the fuse yet its a french plug so how would i acces the fuse ?
      • stuckylad
        • 991
        if its a sealed plug m8 i would just cut the plug off and rewire it to a standard one,double check all leads arent loose first though
        • vtorres
          • Sep 2009
          • 159
          A sealed plug, what do you mean by that ?
          • Manic01
            • 5117
            He means theres no way of accessing the wires in the plug.
            • vtorres
              • Sep 2009
              • 159
              Thanks erm yes there is now way, so you are suggesting to cut off the top n rewire to an english plug ? Would i have to buy an english plug sepeate or just cut off the top of a normal useless plug say the dvd player ?
              • vtorres
                • Sep 2009
                • 159
                The plugs have been swapped but there is still no power going through the circuit board the reason i tried for a factory reset was because it kept saying invalid box.
                My dad thinks power is not the problem and something with box may be wrong.
                • satsmo
                  • 6397
                  Looks like the bootloader is dead, did you flash the box with V1.12 recently? The PSU is fine it wont boot with the loader erased.
                  • vtorres
                    • Sep 2009
                    • 159
                    Nope i have not touched the box with flashing or usb flashing, because there was no need.
                    • satsmo
                      • 6397
                      If it said invalid box on screen over a few instances the bootloader has failed. Did you power it down completely from the main switch on the back of the box before it died?
                      Look at the back of the box can you see a red led light coming from the SP/DIF port?
                      • vtorres
                        • Sep 2009
                        • 159
                        Yepp you can see a red light.
                        • satsmo
                          • 6397
                          So indicating that the PSU is fine but the bootloader is erased.
                          The Max232 interface could be used to fix bootloader faults on the Starview 4 but not on the Starview 5 unfortunately. I have seen a fleabay link for someone who says that may be able to fix an SV5 bootloader fault.
                          I never recommend these sites but it may be your only way of getting it repaired.
                          Here is the thread I posted the link in http://www.digital-kaos.co.uk/forums...ode-fix-97210/
                          • vtorres
                            • Sep 2009
                            • 159
                            Thanks but i am not in the situation where i can buy online im afraid . Also i would not be allowed to pay money for something that might work.
                            • cactikid
                              • 12017
                              is box under a year old contact supplier and see what they say
                              and the new firmware only came out to stop the box from dieing ,dont open up as warranty void,might have to tell them you changed the plug as you thought it was faulty.
