starview 1
  • bhav
    • 16
    starview 1
    can someone please help my starview box 1 wont come on,
    nothing on the display, tried changing fuse but no luck
    many thanks for any suggestions???
  • satsmo
    • 6397
    Have you flashed it recently? If not have you had a look at the C11 capacitor on the PSU board. If it is bulging that may be your problem. Replace it with a 16V 1000uf cap. Maplins stock them at 50p each.
    • bhav
      • 16
      starview 1 dead wont come on
      Thanks,
      how do i do this?
      any help will be appeciated
      i dont know what it looks like when box is unscrewed
      thanks once again
      • satsmo
        • 6397
        Have a look here http://img89.imageshack.us/img89/725/svcapfixpnggv2.png
        Its says 10V in the picture please use a 16V as said. Dont bother removing the C21 either. I have asked Martin to update the picture.
        • utdman
          • 183
          I have the first generation box
          i have exactly the same problem but i was told that it will need to be jtaged?
          last night before going to bed i switched it off and this morning when i tried turning it on via the mains, there was nothing on display.
          • satsmo
            • 6397
            Jtag if the TSOP is corrupt not if its just a cap issue.
            • utdman
              • 183
              whats a TSOP?
              • satsmo
                • 6397
                Chip that takes the firmware, you need to reprogram via Jtag if corrupt.
                • utdman
                  • 183
                  i have removed the cover from the starview and had a look at both c11 and c21 caps.
                  the c11 '+' sign on the cap is still there and there seems to be no leakage.
                  is the method only if there is '0' displayed on the front?
                  • satsmo
                    • 6397
                    Yes it is. But you have edited your OP to a 1st gen box now, why? The C11 doesnt have to be visually damaged to be faulty you need to check the voltage going to/from the PSU with a multimeter.
                    • utdman
                      • 183
                      sorry i should have posted the correct box details in the orginal post first time.
                      • satsmo
                        • 6397
                        No apologies needed I just wondered why you changed your post. Is there any power going to the PSU? Is there anything on the front display?
                        • utdman
                          • 183
                          theres nothing on display.
                          not sure if theres any power going to the machine never used a multimeter in my life
                          • satsmo
                            • 6397
                            You could Jtag it but my advice is bring it to your local TV repair shop first and they will check the PSU for you.
