starview 5 usb 2
  • jackbauer24
    • Mar 2010
    • 10
    starview 5 usb 2
    hi-i downloaded and used the codes, and all channels were working .......for 20 mins.
    i then had to re scan and go through the procedure again.....and again....and again.
    how can i do it without losing channels?????????/
    i got the starview 5 for my dads birthday, so i would like it to work for him.
    any ideas??????????anyone
  • cactikid
    • 12017
    if you have reflashed box no need to manually enter data,factory reset 0000 to delete,auto scan from direct feed from wall to box,no splitters,then enable keycode and also set default key and exit out to a sly channel ,box should update in 2 mins.
    • jackbauer24
      • Mar 2010
      • 10
      hmmm
      i didnt quite understand, sorry!!what is a reflashed box!!!???
      i uploaded the files, pressed 1570, picked NTL, auto scan and all was fine.(there are no splitters)
      do you mean press 0000 instead of 1570?? as well as resetting??
      i am confused and new to this...
      could you PLEASE give me a step by step????
      also-do you think i have the most up to date firmware??
      • cactikid
        • 12017
        v2.03 is the one to use make sure that is what on box in system info if not read this.
        Digital Kaos - Downloads - SV5 tut
        this is the file to use
        Digital Kaos - Downloads - TheboxSuperUSB2_v2.03.20090923.BIN
        warning do not insert or remove usb flash drive while box is powered on.
        if v2.03 is on box then start from scratch,
        press menu select factory reset/default ok
        password is 0000 to delete all channels,
        box will reboot
        installation select your provider
        make sure your boxes coaxial cable is straight into wall socket,
        auto scan your provider,
        found 344 channels depends on area how many,
        exit out then press menu1570
        look for keycode enable and make sure it is enabled,
        exit out to a sly channel for updating.
        a reflashed box means your are updating the firmware to a better one hopefully
        • jackbauer24
          • Mar 2010
          • 10
          thanks, ill give it a try, and let you know
          thanks for that.....
          • evoxxx
            • Aug 2009
            works great
            hey thanx for the info guys it works a treat
            • dingbatok
              • Feb 2010
              • 4
              i think a nagra 3 has hit my box, but im unsure, i reset the box 0000, Then USB the last satmo's firmaware then run it, i turn the sv 5 off unplug the usb, i turn it back on do a scan tellewest west midlands, brings up the ch but all channels are blank, cant get into the 1570 option now, any idea's kind people, i have a starview 5 usb telewest dudley area
              • cactikid
                • 12017
                check what firmware you put on box,follow post 4,if you are on n3 box will not update.
                • jackbauer24
                  • Mar 2010
                  • 10
                  i downloaded v 2.03, but it came up as v2.05, so i presume its the correct one, but my picture keeps freezing(actually my dads picture!!!)
                  either way, its a royal pain and would appreciate assistance in sorting!!!!
                  i cannot find a link to download 2.03.
                  (picture freezes literally every 4 minutes or so)
                  Glasgow area, by the way
                  • larryoke
                    • 404
                    Try here
                    • jackbauer24
                      • Mar 2010
                      • 10
                      thats the one i have...
                      so frustrating as picture/sound/all channels work great...
                      • larryoke
                        • 404
                        Try this one with thanks to DESSERTDOG
                        Digital Kaos - Downloads - SV5 2.03
                        • ruby
                          • Feb 2010
                          cant seem to open file help
                          • cactikid
                            • 12017
                            you dont open the file its drag and drop.
                            • shippers1066
                              • Apr 2010
                              That has helped me as well. Just trying it now. will let you know I a moment
