the box pvr
  • chris25
    • Apr 2010
    • 10
    the box pvr
    hi the channels on my box pvr are there but says updateing all time ive got firmware 8_dec2008 done the Factory reset it, rescan channels with an automatic scan, gone into parental control, then pressed then 2007, key emu to on.
    Then in the menu turn the key code to on done this about 10 times my son was in the channel upgrade from hdd the box was on till this happenet any help is appreciated im in Teesside
  • smoggy
    • Apr 2009
    • 12806
    Hi and welcome to DK
    first off give the young un a clip round the lug.
    I have had no experience with this box but if it happened when he changed something in HDD mode have you tried whatever other options are available in that mode.
    when you turn emu on have you also set default key
    • chris25
      • Apr 2010
      • 10
      hi yeh done that mate still not comeing on had the box 3 years now never done this befor ?
      • smoggy
        • Apr 2009
        • 12806
        start from scratch and reflash the firmware and see if you have any luck
        • chris25
          • Apr 2010
          • 10
          hi were can i get the firmware from ?
          • smoggy
            • Apr 2009
            • 12806
            firmware here Digital Kaos - Downloads - Starview TheBoxPVR Software & Instructions
            • chris25
              • Apr 2010
              • 10
              hi this the firmware dec 08 v3.105
              • smoggy
                • Apr 2009
                • 12806
                yes thats the firmware, it needs to be loaded to your box using the loader
                • chris25
                  • Apr 2010
                  • 10
                  still not comeing on put the firmware on it dont no what to do now ?
                  • smoggy
                    • Apr 2009
                    • 12806
                    have you checked in system information to make sure firmware has loaded ok
                    • chris25
                      • Apr 2010
                      • 10
                      yeh its all on ok but not comeing on im in stockton
                      • chris25
                        • Apr 2010
                        • 10
                        its all on ok in the system information
                        • smoggy
                          • Apr 2009
                          • 12806
                          if you have the latest firmware and turned emu on and set default key then put on SKY SP1 and it won't update then there is not much else left to try.
                          did you scan on NTL provider
                          have you tried inputting the codes manually
                          • dell_xps
                            • 2558
                            set default key !!!
                            • chris25
                              • Apr 2010
                              • 10
                              yeh set the set default key still not on have you got the codes so can put in manually thanks
