Ive got a Starview HD Combo+ lan box I was watching it last night when it froze now all the channels say they are scrambled. Ive tried to retune and although it finds channels they are all scrambled please Help!!!
Can anyone help please
Tags: None
Have you made sure that you are not in a Nagra 3 area? Check here http://www.digital-kaos.co.uk/forums...tml#post580588 for latest info.
If so and you are not in an N3 area, turn the box off and then back on from the main switch and see if it resets.
If not factory reset and follow this particular extract from the SV HD sticky readme:
To scan your channels, so go to installation press the right arrow button again and go down to AUTO CABLE SEARCH all you need to change here is the symbol rate.
The symbol rate determines your area for example nt* is 6887, the other 6952 are for telewe*t and EXc&w.
When you have selected your area go to start scan.
Once the scan has finished go to menu then highlight accessory and on the remote press the numbers "8989" you will then see
"keyedit" appear on the right hand side, go to it and press ok and just check that auto update is on if its off just turn it on.
then go to to your channels by exiting the menu and pressing ok.. Select a non FTA channel and leave it until a picture appears
I refuse to answer that question on the grounds that I don't know the answer. - Douglas Adams -
No luck
Did what you said no luck think im in a Nagra 3 area what does this mean and how to I sort it out any ideas thanksComment
Read through the many threads here and you will see there are a few boxes using cardsharing as a method around N3. Your box may come online as part of the SV CS server. Which you will have to pay for. You need to get in touch with the supplier of your box.
But we cannot help you as to how to connect to it, (if indeed the SV HD is going to), due to our rules in relation to CS.I refuse to answer that question on the grounds that I don't know the answer. - Douglas AdamsComment
