starview 5 Box suddenly stop indicating no signal
  • afnan
    • May 2010
    Hi All!
    I live in harrow middlesex. I was using starview 5 box. About 4 days ago, at midnight our box stoped working indicating no signal. When I checked the internet, it was also down. So I contact the Virgin Midia the next day. I found that there was a fault in our area and the engineers were working on it to fix. At that time I also tried virgin own box, but it wasnt working either. The service was down for about 3 days. I contacted the virgin customer service again and I was told that the service is back and just switch on and off ur box from the mains, and it should work. I done the same and it start working. Later I tried the starveiw 5 box, but it was still showing no signals. I lost all the channels. Any help will be much appreciated. Thanks in advance.
  • brainwave
    • Mar 2009
    • 209
    if you have received a new red card from virgin over the last few week's you will now be aware that all areas and i say all areas in the Uk will be switched over to Nagra 3 encryption which means all dodgy boxes all chipped provider boxes will stop working.
    At the present time there is only 3 boxes that are working on N3 in the Uk
    1 Kryptview
    2 starview 6
    3 starvied combo
    so take your pick from above if you want to remain watching your tv without paying over the odds for it
    • daiotonka
      • May 2010
      • 5
      N
      I Thought no box would work when Na 3 came on?????
      • cactikid
        • 12017
        it is a work around way of receiving tv.
          It's called card sharing. Discussion is not allowed on these forums. Even if you read up and decide to go down this route, it is not free. Some of the prices i have heard are nearly on a par with legit subs. Ask Mr. Google he will tell you all you need to know.
