hi every body i have an sv6 i'm connected to the internet every thing is switched on but still says not connected tried everything new ethernet cable reset everything still no joy
maybe server is down again like last week, do you know someone else who has one, are theres working?
Your star view needs to no your ip addreess to work properly go into cornextions and auto ip address the box will reboot then go to manual set it needs to no your statice ip address if you have no ip adreess you will get problems mine is working briill for now, hope this helps,
did you try asking your supplier, i noticed satdownloads did not give you any info, and their sponsored by importers!
satdownloads are too paranoid so they told me to get lost, satdownloads belongs to *************** and he's probably had the authorities on his case seen as he is *********.
I hope these posts help people make a better judgement on what to go for, I hope starviews proove me wrong but so far its been a real piss take. The guy I got it off is in Ireland so he's no good to me, However I did contact another supplier who did confirm it was server issues again. He still had the cheek to try and flog a batch to me, I said no chance. I'm jumping ship to kryptview.
I don't like the A750 as no LAN port so you need to get a I-connector device which is way overpriced and more wires!
the HD version of kryptview I can't fault it but I can't afford ?200 just yet, the A780 is the best option as it has the lan port and is priced closer to the ?150-160 mark which is alot more reasonable
