How to put fta software back onto starview hd combo
  • thekings
    • Sep 2009
    • 68
    hi does anyone know how to put fta software on a starview hd combo lan. i have carling on at the moment but when i put the fta software onto usb on the starview and try to update it says update failed at 20 percent. can someone help thanks
  • chuckles53
    • 320
    fta
    you need to use the old bootloader method connecting the box with a rs232 cable,you can get the loader and software from the bigmac toolbar.
    • pongo snodgrass
      • 178
      You will need:
      A computer with a serial port
      A Null modem 9 pin serial cable (as used on the starview 1 - 3)
      Connect the SV HD to the computer using the serial cable and attach to mains (leave turned off by switch on back)
      UNZIP the file downloaded
      open HD-200_Download.exe
      Choose COM 1 (unless you have connected it to a different port)
      Select software (HD300N_SC_RS232_1.bin)
      Turn on receiver with rear switch
      bar will start counting to 100%
      WAIT UNTIL SOFTWARE SAYS COMPLETE!!!!
      Turn off receiver and back on
      P.S. This will also recover 'bricked' SVHD's (if there are any lights still on)
      Once complete the receiver will be as factory provided.
      If your Starview HD has lost its MAC address this is what you need to do next:
      Go to accessory - network - ip config
      Set IP to manual
      You can now edit the MAC address back to the original receivers address - Your mac address is on a sticker inside the receiver (you can see it through the vents on the top)
      apply then exit.
      Then you can start from scratch loading which ever firmware you choose.
