SV4 - low level audio
  • tony_i
    • Oct 2008
    • 425
    The audio from my SV4 is low compared to the normal tv level.
    I have to have the tv !!!BLASTING!!! out before I switch the box on or the volume level is so low it's inaudible.
    I seem to be losing some audio strength inside the box somehow??
    Anyone have any ideas?
  • satsmo
    • 6397
    Have you set the volume on the SV4 to max? Is it set to PAL, in menu - User setup - Av Output Settings. Also make sure your scart, is pushed home firmly on both the SV & TV. Also make sure the scart is in the socket marked TV scart on the back of the SV.
    • tony_i
      • Oct 2008
      • 425
      These are all fine.
      The problem is that the SV4 volume is at max to get a reasonable output without setting the TV level itself to mega loud.
      It's not a big problem and totally useable - just seems strange that they're so out of synch.
      • satsmo
        • 6397
        Have you tried a different scart lead? Or composite leads?
        • blues beno
          • Oct 2008
          • 13
          I've just got my SV4 and I have a slightly different problem. I have NO VOLUME on some channels but on the standard channels BBC1- CH5, I do have volume, so it can't be a connection lead issue. Any ideas anyone???????
          • nsw9154
            • 259
            i had the same problem with no sound on most of the chanels i did a cold reboot - turned the unit of at the back left it for 30mins switched it back on and the sound came on
