Starview 6 Server down in 6887!!!
Tags: None
They will come on maybe after 20:00 hours today.
WARNING:
My post is for educational purposes only and should not be taken seriously
WELCOME TO OUR WORLDTools owned: Hammer, Chisel, Crowbar, Punch, Chainsaw, Cutter and Brain!!!
Note:All information given is to be used for educational purposes only and should not be taken seriously.Comment
server down
you need to go to network then cs net and turn ustream of and come out then go back in to network then cs net and turn it back to ustrem then exit then go back in to cs net and it will say connecting,just wait untill it says connected then exit and go to sky sports 1 and wait a few minutes and it will come back on.Comment
Hi guys sv we'd doing an update on the server therefore the connection was intermittent! Although it was completed at 19:00 gmtComment
please press the little red THANKS tab
if I helped
if not press the green tab to tell me to f**Koff
