The flash file required is in the downlaod section, not sure if you have enough posts to view though. I did a search and this is what it says to do for starView 5 so it be moreless similar, however im not sure if point 19 is correct, i would need to look at what i typed when at home, althoguh someone on here may help you before then.
1. Plug in the starview 4; attach the cable feed to the cable input on the back of box
2. Plug the box in to the TV using the usual scart lead.
3. Download the required firmware for the box from Internet.
4. Format your usb drive to FAT32
5. Copy logo & bin file to usb drive (copy/paste)
6. Whilst starview is off - Insert the usb pen drive at the back of the box
7. Flick on the power switch also at the back of the box
8. Power the box on with the remote.
9. Check your TV settings are set to video output RGB and set to PAL
10. Now machine is on - press menu on the remote
11. Scroll down to the usb option in menu and hit ok,
12. Here you will see the files on the pen drive.
13. Highlight 1.07 firmware file and press ok.
14. Highlight the logo file and press ok.
15. Once the firmware and logo files have loaded onto the box:
16. Go back into menu and highlight installation and choose automatic scan hit ok
17. Choose the provider for the area you are in and Select the correct one and hit ok.
18. The box should now pick up the desired channels.
19. Go into menu and key in 1570 with the remote,
20. This will bring you to the secret menu.
21. Highlight keycode and change it to ON.
22. Now you’re all set to scan
23. Exit out and put your box onto S*y sports channel
24. Wait for it to update. This may take a while.
25. Sit back, grab a beer, and enjoy.
