Sky EPG for Starview?
  • maney266
    • Sep 2009
    • 44
    if it can be done for dreambox's by using the radio channel EPG data 1 cant it be done on starviews?
    "SKY UK EPG with Nabilosat
    "Sky have thier EPG in a format starting to become a new standard, up till now we have heard of Media Highway [MWH], which is the old standard for EPG, and see on channels like DigiTV. Sky uses OpenEPG, and this is normally sent down a specific transponder; so 1/2 the battle is finding the transponder.
    For the UK its HIP HOP [frequency 11778, symbol rate 27500.
    ] radio station, so we will setup Nabilo to trigger OpenEPG fucntions if we set the channel as HIP HOP Radio. - pretty simple stuff.
    Ok - stop the waffle and share the action - Set up First.....
    First a decision. If you use Dreambox Edit - this i suggest you add HIP HOP Raido to one of your easy get TV boquetes so you can use the remote easy to get updates. there is about 8 days data in the stream
    If you dont care to use dreambox edit the this will work - Enable Alternative Radio mode
    Press MENU, and browse to SETUP>SYSTEM>CUSTOMIZE and set Alternative Radio mode to YES. This procedure will give you the option to zap through radio channels in radio mode, and have the full MENU active like in TV mode
    Configure for Download
    Press the Blue button to access to Nabilosat Blue Panel
    Pess it again to open the Nabilosat E2 settings. Move the cursor to Nabilo E2 EPG, and press OK
    The Nabilo E2 EPG Settings panel will open
    Press the red button to modify settings.
    * You should Enable the OpenEPGloader
    * Select the path where to save the EPG
    * Select the Hip Hop radio channel
    * Press the red button again to save your settings.
    Enigma2 will be restarted!!!
    Once Enigma2 has restarted
    * Change to HIP Hop Radio Channel
    * Press the Blue button to access to Nabilosat Blue Panel
    * Pess it again to open the Nabilosat E2 settings.
    * Move the cursor to Nabilo E2 EPG, and press OK
    * Press the yellow button. The channel list will popup.
    * Press the green button to update the list of channels available * Now - back in the list, With the keys left/right set each channel to YES if you wish to download its EPG, or to NO if you wish to exclude it. Scroll up/down with the keys up/down.
    Thats it Dreamers! you are all set.
    Change away from Hip Hop, to some other channel, then Change back to Hip Hop. Wait 10 seconds and the new list will populate.
    I needed to reboot the first time for the Cache to work on all the channels after the download completed; and then change to Hip Hop every few days. you can automate that in the EPG Settings menu if you prefer
    This is what youll be seeing....
    Wait for the countdown to be over.
    EPG is stored in the normal enigma cache so all epg modules should appericate this "
  • dandanthegardeningman
    • Mar 2010
    • 65
    SORRY TO SOUND LIKE A DUMDBOW DOES THIS EPG WORK ON ALL DREAMBOXES MATE THANKS
    • maney266
      • Sep 2009
      • 44
      ive only been looking into it for a few days since im thinking of selling my starview HD and getting it. From what ive seen on forums it only works if your using nabliosat image thing on DM800/DM8000
