starview 7 problems
  • peterpan01
    • Jul 2010
    starview 7 problems
    hi all.
    i hope some one can help - i have a starview 7 and want to connect through my onkyo tx-sr607 av. the starview only has scart were the av does not. i used a scart converter to composite, red white and yellow, then connected the composite to cbl input on av. but i have no sound or pic. the starview works ok connected to the tv via acart. av is working ok with other units connected to the same inputs. THANKS
  • cactikid
    • 12017
    not to sure is there a spdif optical port if there is just use that
    to onkyo
    • peterpan01
      • Jul 2010
      hi - thanks for your reply - no optical output on starview 7 just tv and vcr scart
      • EAMO 2
        • 1201
        Originally posted by peterpan01
        hi all.
        Why not leave SVU7 in TV scart & connect other unit to TV av.
        • peterpan01
          • Jul 2010
          thanks for your reply - i want to connect to the Onkyo av to upcsale the output to tv at 1080i. the picture quality from the sv7 is not that impressive. but i cant understand why the av cant see it. i tried another experiment yesterday. i installed an old dvd player using composite connections to the av. all worked well. i then fitted a scart converter to composite from the dvd, now it is unable to find the dvd player. your help would be appreciated.
          • EAMO 2
            • 1201
            Check scart converter is rated as output, some are input only.
            Others have a switch to change from input to output
