Starview and N3?
  • nature
    • Nov 2010
    • 144
    Starview and N3?
    I heard even starview will be going off shortly like the DBOX and Eurovoxs. Is there any truth in this? People are saying this is because VM will be changing over to N3 connection or something.
    Can anybody shed some light on this?
  • EAMO 2
    • 1201
    VM have already changed to Nagra 3 encryption. Kryptvu A780,
    Stvu 6/7, & Ddigital-Duo use the LAN connection to connect to
    internet to decode Nagra 3 encrypted channels. Providers may
    devise method of closing off this workaround Nagra 3, and they
    may not be able to close it off. It's a chance you take.
    • nature
      • Nov 2010
      • 144
      thank you for that mate. Which of the boxes you mentioned above do you recommend? and do they not require some sort of c/s?
      • cactikid
        • 12017
        kriptview 780 best cable box,needs a coaxial feed and a lan/internet feed.
        the old sv6 that were bought last nov 2009 are now been switched off=times up.
        • safc1234
          do you no if that is the end 4 sv 6,
          • cactikid
            • 12017
            limited connection life if lucky a year=off,buy a new box.
            why do you think kv is better =lasts longer and better supported,thats why i dont like keeping up with the jones.
            • nature
              • Nov 2010
              • 144
              thanks for that info. what is an coaxil feed?
              i have a virgin broadband at home.
              • spangla
                • 5
                i have a starview 5 box usb , and nagra 3 has come in and ive lost some channels , has anyone cracked this yet !!!!!!
                • spangla
                  • 5
                  virgin is a coaxil feed ,
                  • boomer39
                    • 2818
                    er NO.....MAYBE TOMORROW....
                    YNWA..
                    • nature
                      • Nov 2010
                      • 144
                      THANKS guys,
                      I just checked on ebay KV 780 boxes are more dear. Their going for something like ?150 odd. Which is more pricey than SV. So if their better I might aswel invest in them?
                      Also are they as easy as SV to setup? as in installing the firmware and connect it to the LAN and start using it? is that all???
                      • cactikid
                        • 12017
                        same connection that plugs into tv,but with broadband only you may have a weak signal if you intend to use a box
                        signal needs to be around 80 ish to work well.
                        • cactikid
                          • 12017
                          THANKS guys,
                          to work best you need a live coaxial tv signal to scan and a lan connection
