Correct way to flash!
  • blairco
    • 4
    Connect your box to your Pc with a null modem cable, power up the box. On standby!
    click on the GTROM file and press download, once your download says complete leave it another 20 seconds to make sure it is complete
    That?s your box now flashed with the latest software...
    Connect your box to your TV via scart lead and power up
    you will now see a menu, Go onto English and press OK, Installation OK
    Make sure you?re on the correct cable provider, i.e. TW, NTL or whoever it is
    go to auto scan and press OK
    This takes around 20 min, and after this it will tell you how many channels are found
    Now press OK then EXIT EXIT
    Now don?t do anything else but this
    Aim the remote at the TV and press 1 5 7 0
    scroll down to Set Default Key and press OK
    Scroll down to EMU and turn from OFF to ON
    Now press Exit Exit Exit
    Go onto sky sports 1 and let the INFO UP Date which might take a few minutes
  • stokie63
    • 47
    do you have to do a factory reset b4 you flash the box so everythings clear or can you just flash it even if you got your channels from manual keys.
    • raoulduke10
      • 7
      null modem
      sorr what is a null modem?
      • laptops
        • 4
        laptops
        bit confused with all these boxes
        • sk0rp10n
          THanks for this Blairco... Do you know where to find the flash file, or what the best flash no update I should download when I find them? BTW
