Starview 7-Carling 1.03
  • EAMO 2
    • 1201
    #31
    Originally posted by stevie84
    same iv downloaded and installed nothing working
    Use this firmware
    Digital Kaos - Downloads - Starview 7 Carling V1.04
    Have a read of this
    Digital Kaos - Downloads - starview 7 Firmware & Instructions
    If you have problem post back with exact details
    • jatt
      • Dec 2010
      #32
      how to install carling 1.04 on sv7
      • EAMO 2
        • 1201
        #33
        Read this
        use this firmwarehttp
        • shinuraj
          • Dec 2010
          hi i am a newbie.. i downloaded carling 1.03 and i selected usb and i can see the file carling 1.03 file there but when i pressed oK on my remote nothing is happening.. any idea how to install it... please help
          • cactikid
            • 12017
            #35
            read above posts as links are there,welcome to dk.
            Digital Kaos - Cable & Satellite Forum
            • EAMO 2
              • 1201
              #36
              After you select USB you need to Hi-lite Carling 1.03 before you
              press OK. You would be better to use latest firmware for SV7
              • martina30
                I have carling 1.03 firmware on my starview 7, it has scanned all the channels but im only able to watch freeview channels. Do I need to get another firmware? many thanks
                • smirnoff_rules
                  • 8603
                  #38
                  is your box connected to the internet
                  • EAMO 2
                    • 1201
                    #39
                    SV7 should work with Carling 1.03 if you went thru set-up steps
                    correctly; select U-stream, turn EMU on, etc.
                    Would be easier for you to flash box with latest firmware
                    All the settings are preset for UK on 1.04 firmware, you may need
                    to restart router & box for box to connect to internet
                    As said above make sure router is connected box-Lan adaptor
                    • bonesarsenal
                      brilliant thanks
                      • mickeypro99
                        • 6
                        #41
                        i have dowloaded carling 1 03 and turned usstream on and its still not connecting ! is it ok to use an ethernet cable to connect . its still blank in the ip address in fact they r all blank . i av rebooted , done a factory reset , even tried carling 1 04 still says not connected
                        please help me guys .
                        • EAMO 2
                          • 1201
                          #42
                          Ethernet cable is fine. Make sure it's OK & connected properly to
                          router & adaptor to RS232 port on box. If you're having problems
                          connecting best to stick with Carling 1.03 firmware. Try this one
                          Digital Kaos - Downloads - Starview 7 Carling 1.03
                          Have a read thru tutorial
                          With 1.03 f/ware you can access settings to make sure they are
                          all correct. With 1.04 they are pre-set. When you have box working you can upgrade to 1.04
                          Before you do anything look in UTILITY--SYST INFO & make sure f/ware you flashed is listed.
                          You could also turn off box & router, reboot router then reboot
                          box. Often does the trick
                          • mickeypro99
                            • 6
                            #43
                            thanks mate ! still not got any ip adress listed tho . im stumped
                            • EAMO 2
                              • 1201
                              #44
                              If answer to other thread doesn't help there's an easier way.
                              If you have X-box or other console connected to internet copy down all IP,MAC, etc from console. Disconnect console from the
                              router & enter values in SV7. Don't forget to SAVE values.
                              Reboot box & it should be OK. Console can then be reconnected
                              to router & auto-reconnected to internet
                              • mickeypro99
                                • 6
                                #45
                                thanks for ur help eamo , i'l take it to my mates house wher he has ps3 online
                                cheers
