Newbie- Help needed? starview
  • biggazjones
    • Dec 2010
    Hello I'm another newbie, and would like advice/help with deciding what to do?
    1.) Do I need an ACTIVE cable line for the starview to work? Such as a basic package?
    2.) Is starview 7 or Kryptview A780 better and easier to use?
    3.) I know you need an adaptor for one of them, but which one is it and whats the adaptor?
    4.) Is there an actual picture guide to do the setup or is it easy enough to follow the instructions on the downloads page?
    5.) how long does it work for? is there a chance of just buying a box and it being useless within a month for example.
    Thanks for any help that is posted, hopefully you will know alot more than me, I have done alot of research on them both and now about the firmware etc, and I'm quite good with tech, but I'm a total novice when it comes to this type of tech.
  • EAMO 2
    • 1201
    Yes you need cable connection & broadband connection
    Kryptvu seems better but is more expensive
    Adaptor comes with required box
    Easy enough to follow tutorial
    Who knows how long they will last
    • herts2201
      • Dec 2010
      Sybole Rate for Luton
      Hi!
      I am another newcomer. can i ask what symbole rate for luton is?
      another question. it says in tutorial scan without splitter. I have cable connection and broadband connection from virgin media. is it just for scan or i can not use virgin broadband for starview 7.?
      many thanks in advance
      • EAMO 2
        • 1201
        Originally posted by herts2201
        Hi!
        It's OK to use VM b/band. I would scan without removing splitter
        to modem, if it's not finding all channs remove it & then scan
        Symol rate for Luton should be 6887, if not use 6952
