starview 7 lan
  • staylor
    • 4
    starview 7 lan
    hello folks, with my starview 7 the cable that comes from the modem can i split it with an ethernet 5 port switch to feed router and starview at same time , will this work ?
  • EAMO 2
    • 1201
    Why f**k around when you can simply connect LAN-cable from
    SV7 into router. If your router LAN ports are all in use Then
    connect ethernet hub into router NOT modem
    • staylor
      • 4
      got starview 7 today and up and running in 30 mins,watched channels for couple hours then dis, connected to swap cables around reconnected as before and non fta scrambled , several attempts with all settings and still same- confused
      • EAMO 2
        • 1201
        Plug out router & box. Power-up router, then power-up box
        • staylor
          • 4
          all ok now many thanks
