Press the default key, (press menu - press 1570 you will see it there), and exit out to a Sly channel. Presuming key emu is on and you have it updated with the latest fix, that should sort it.
If you pressed the default key and they are staying like that, then turn the box off for a few seconds from the back switch and then turn it back on. Press the default key again and see if it updates.
Last resort is a factory reset, turn key emu back on and rescan.
