hd combo and sv7
  • chuckles53
    • 320
    hd combo and sv7
    SEE WHEN YOU PUT THE LATEST SOFTWARE ON THE STARVIEW7 AND HD COMBO THERE IS A DATE NOW FROM WHEN THE BOX WAS FIRST CONNECTED AND IT GIVES YOU A DATE 1 YEAR ON FROM WHEN IT WAS FIRST CONNECTED.SO IF YOUR BOX WAS FIRST CONNECTED ON 17/6/2010 IT GIVES A DATE OF 17/6/2011.CAN ANYONE COFIRM IS THIS THE DATE WHEN THE SERVER WILL SHUT THE BOX DOWN AS IT WOULD HAVE BEEN ON FOR A YEAR.
  • cactikid
    • 12017
    yes and no shouting,use lower case only=no caps.
    1 year box
    • sshhiinnee
      • Nov 2010
      • 83
      Hd Combo+ date
      After down loading the latest firmware it showing me the expiry date in Network ( HS Net status showing me 2011-05-01).
      If i down grade to the eariler version FW:- Carling+_F531_1207.UAD
      will this make any difference to the life span on the SVHD+
      Also i noticed more SV owners have the same expiry date 2011-05-01? how come
      • cactikid
        • 12017
        starview have a 1year policy connection to server
        • mark8393
          • 2305
          if people have same expiry date, i may surprise you with this answer, but they connected the same day as you, they do sell more than one a day.
          where is all this starview lifespan coming from, these were sold from day one with 12 month cs.
          • cactikid
            • 12017
            easy no research done,buy a box and hope it works,ohhhhh do i need a cable feed
            • mark8393
              • 2305
              yes, spot on, half hour googling would give people answers
              • sshhiinnee
                • Nov 2010
                • 83
                So Guys,
                In order to keep having cabling viewing all channels. i must buy another new Starview HD, which will have 1 year channels after configuring.
                or
                when my starview hd finishes in May, will there be a better box in HD, a starview 8 HD?
                Thanx
                • mark8393
                  • 2305
                  bbers
                  So Guys,
                  or
                  Thanx
                  best bet is use sat side, dont use the online robbers, there are cheaper and better options
