Sorry for the late reply Mate , on my old starview 1 , all the sultana channels came in on 354750KHz .
The box super has them with correct I.D. , on 434750 (sultana sp1) ,348750 (sp 2) and
426750 (sp news) .
Hope this helps .
if you go to channel 538 then press menu then installation, manual scan where it says down frequency type 347000 then ok to start scan when finished go to channel edit skip delete whatever scroll to channel no press ok to view if no picture comes on this is the duff channel select with < >(vol buttons) to skip or delete keep scrolling until you have selected all relevant channels then press exit when you have exited to telly all channels should be where they should be,worked for me.
setanta channels are in the BICS channels at the end of the list of all channels list.... i did a factory reset,autoscan,turned emu and default back on ,exited to sky sports waited for the box to update .... and everything went back to where they should ... even the sky channels ...hope this helps ..big
Thanks Guys
I just found all my sulanta sports and I found ITV2 again that thought was lost.
All this by scrolling thru the All Channels menu and following your advise.
Cheers
Stevie
I didnt have 2 iof each channel. just a message saying removed service. Ive followed all advice posted. no luck.
Never heard of that one before BobbyX, have you lost all signal maybe???
If not, why not try this...
I don't know if this will be a help or not, but I lost some channels a few days ago and I couldn't get them back using the automatic scan...
Instead I clicked on manual scan, dropped down to the network scan box and set it at ENABLE, then pressed the ok button...
I got the four channels I was missing in there. The manual scan doesn't upset the existing channel order you have, they slot in behind the last of your present channel order -
PS... Make sure you search through all the newly scanned channels to find the missing pictures because some are hiding behind un-named ones...
