has any one got there starview 2 box working
  • mhd
    • 17
    with the new firmware please help
  • oldie
    • 32
    Yes I got mine to work ok. I was advised to use the 4.03 version loader to flash the new software. So then I assumed that the 4.54 s/w should be already on the sv2 in order to use this fix.
    In short I flashed 4.54, then the logo file that came with it, and finaly the new fix. All using the 4.03 loader. All is working now and to be sure I changed a few keys to see if it updated, and it did.
    Good luck.
    Note: Viewing Pay TV without a valid subscription is illegal! All the files available here are kept for experimental and educational purpose only!
    • ptolemy
      • 7
      good news, where did u get firmware m8
      cheers
      • janardan
        new starview update please
        • oldie
          • 32
          I think you all should read post No 1 here first. http://www.digital-kaos.co.uk/forums...-update-16910/
          • ramjet
            • 2995
            the new v8.0e bin file works ok , done 2 original sv2 boxes tonight and no problems
            • iancolsean@googlemail.com
              I got my sv 2 the box up and running with this firmware but the general census is that if your box is NOT original it will NOT work . So if in any doubt do not try this until a new fix appears.
              • Monster_red
                Originally posted by [email protected]
                Not sure about that.
                I've got an original that had 4.54 on before the patch and it's still not working.
                • ramjet
                  • 2995
                  reload the 4.54 flash and the logo bin files and reboot and check that all works , then factory reset and load in todays file and wait for the reboot to the setup screen , then set default keys and emu on and rescan
                  • oldie
                    • 32
                    Good luck.
                    Yes Thanks oldie. you bunch of ingrates.
                    • tipster69
                      • 91
                      Good luck.
                      THANKS for the heads-up.
                      • Philpass
                        Working and thanks
                        Been waiting patiently since the big UK crash, and updating keys manually (thank you Keymaster). Just used the new firmware, logofile and loader and everything seems to be working just fine.
                        I'd like to say thanks to all those who have been working in the background to get us back watching all the channels again, and also to the D-K crew for helping keep us informed and helping us access what we needed when it became available. At times it was probably a pretty thankless task as thousands of newbies like me clamoured for information, but thankfully you kept your heads above the water, and managed to save not just yourselves, but us lot too. You are all a complete bunch of super-stars!
