STARVIEW HD COMBO
  • peajay20
    STARVIEW HD COMBO
    Hello,can anyone let me have the latest update for my starview 6 lan hd combo. I last updated in July.
    Cheers
  • EAMO 2
    • 1201
    Cheers
    Digital Kaos - Downloads - Starview HD LAN Combo Carling+_F531_1207
    This is for HD Combo LAN only, don't use on SV6
    • peajay20
      THANKS TOP CLASS
      • patang
        • Feb 2011
        • 10
        Is this different to the Grooverider file from the 14th Dec 2009? Is this why the channels are also scrambled now on the Combo HD box or is the SV server down?
        • EAMO 2
          • 1201
          Yes this is latest firmware & you should flash box with it, but
          maybe best to wait until server is back on as server down since
          yesterday
          • patang
            • Feb 2011
            • 10
            yesterday
            Thanks EAMO, any info on how to use this box to work with the satellite setup. e.g. what would I need and where do I get it all from. Cheers
            • EAMO 2
              • 1201
              Don't have this box, Bytemaster is your man if he's around.
              Basically you need to connect box to sat dish & scan for channs
              on Astra 28.2 satellite. You can then view all FTA channels.
              You need to either enable Cccam prio on box or download it I'm
              not sure which to view all encrypted channels.
              • youngie1
                • Sep 2009
                • 184
                do i need a specail file for sat. or not i have carlingon it now for cable. please help if you can cheers lee
                • EAMO 2
                  • 1201
                  The firmware enables both cable & sat sides of box. Latest is;
                  If you have any queries about Cccam on sat talk to Bytemaster
                  • youngie1
                    • Sep 2009
                    • 184
                    ok thank you so much mate but can i still put this software on now as i have already got carling on the box. just check so i dont brick my box cheers lee
                    • EAMO 2
                      • 1201
                      Yes you can use that firmware if box is Combo-LAN HD
                      • leshemnoam
                        • Feb 2011
                        Hi to all,
                        I'm a newbie but happy to post results..
                        Is the server still down?
                        Had it all working...went on ski week,
                        broke my leg and came back to a tv with no good channels
                        Anyway thanks for the post
                        • superdon10
                          • 5
                          USB
                          hi can you help. ive downloaded the firmware onto my usb but keep getting "update fail. check your usb memory" @ 20%, what do i need to do any help?
                          • Shady
                            Shite Link King
                            • Dec 2010
                            • 6404
                            do you have a lan socket on your box? if so, are you using the 'with lan' version?
                            if you dont have a lan socket are you using the (without lan) version?
                            • superdon10
                              • 5
                              lan version, with lan socket connected to modem
