Any combo, sv 6 or 7 users.
It would probably be a sensible move if you have any of the above boxes to downgrade your firmware again to the type that allows you to switch on and of manually the ustream on your box.
If it is the case that the starview servers have been rumbled, then all your boxes are pinging away at the server ip looking for a response. With the right bit of kit every single ip that is requesting code in return could easily be logged and TRACED if they hav'nt already started doing so.
If the cable server comes back up well you will here from someone on some forum.
Better to be safe than sorry guys n gals....
Combo Users need to use F5.21
Maybe Satsmo could re-upload this :-)
switch off yer box
until you know its safe or as he said do a factory reset put old filmware back on
