Widescreen on SV2
  • Crava
    • 5
    Widescreen on SV2
    Hi All
    I have installed the new firmware on my SV2 which has worked a treat, however I cant get a widescereen picture now even after turning on 16:9 aspect ratio in the mnu settings. Anyone else experienced this
  • ramjet
    • 2995
    after you have reflashed the receiver you need to factory reset it as well , otherwise strange things can happen
    once its been factory reset you will have to do a menu 1570 and set keys default , turn emu on , and rescan the channels
    • Crava
      • 5
      Thanks, Ive tried that and still no widescreen - Anyone else had this problem/got any suggestions?
      Thanks!
      • grimmerman
        it will stay the same until it picks up the widescreen signal i usually leave it on v**g*n 1 for a bit turn the power off on the tv and box then back on again and then will change to the correct screen ratio. Sorts its self out eventually
        • Doomed
          • 17
          Press the blue button
          • Crava
            • 5
            Thanks will give those a try
            • Crava
              • 5
              The blue button worked a treat - thanks for the help!
              • Doomed
                • 17
                no problemo
