Airplane Maintenence Report
  • Iseecheese
    • Sep 2009
    • 5
    Here are some actual maintenance complaints submitted by US Air Force pilots and the replies from the maintenance crews.
    Problem: "Left inside main tire almost needs replacement."
    Solution: "Almost replaced left inside main tire."
    Problem: "Test flight OK, except autoland very rough."
    Solution: "Autoland not installed on this aircraft."
    Problem: "The autopilot doesn't."
    Signed off: "IT DOES NOW."
    Problem: "Something loose in cockpit."
    Solution: "Something tightened in cockpit."
    Problem: "Evidence of hydraulic leak on right main landing gear."
    Solution: "Evidence removed."
    Problem: "DME volume unbelievably loud."
    Solution: "Volume set to more believable level."
    Problem: "Dead bugs on windshield."
    Solution: "Live bugs on order."
    Problem: "Autopilot in altitude hold mode produces a 200 fpm descent."
    Solution: "Cannot reproduce problem on ground."
    Problem: "IFF inoperative."
    Solution: "IFF inoperative in OFF mode."
    Problem: "Friction locks cause throttle levers to stick."
    Solution: "That's what they're there for."
    Problem: "Number three engine missing."
    Solution: "Engine found on right wing after brief search."
  • bvilleuk
    • Aug 2009
    • 625
    Thanks for this - absolute classic
    WHAT DO I THINK OF CAPITAL PUNISHMENT??
    CAPITAL !!
    BRING IT BACK...............
    • jasbo7
      • 1432
      They come from everywhere eh! but good anyway m8
      Remember it takes a college degree to fly a plane, but only a high school diploma to fix one. Reassurance for those of us who fly routinely in our jobs
      After every flight, Qantas pilots fill out a form, called a "gripesheet," which tells mechanics about problems with the aircraft. The mechanics correct the problems, document their repairs on the form, and then pilots review the gripe sheets before the next flight. Never let it be said that ground crews lack a sense of humour. Here are some actual maintenance complaints submitted by Qantas ' pilots (marked with a P) and the solutions recorded (marked with an S) by maintenance engineers.
      By the way, Qantas is the only major airline that has never, ever, had an accident.
      P: Left inside main tyre almost needs replacement.
      S: Almost replaced left inside main tire.
      P: Test flight OK, except auto-land very rough.
      S: Auto-land not installed on this aircraft.
      P: Something loose in cockpit.
      S: Something tightened in cockpit.
      P: Dead bugs on windshield.
      S: Live bugs on back-order.
      P: Autopilot in altitude-hold mode produces a 200 feet per minute descent.
      S: Cannot reproduce problem on ground.
      P: Evidence of leak on right main landing gear.
      S: Evidence removed.
      P: DME volume unbelievably loud.
      S: DME volume set to more believable level
      P: Friction locks cause throttle levers to stick.
      S: That's what friction locks are for.
      P: IFF inoperative in OFF mode.
      S: IFF always inoperative in OFF mode.
      P: Suspected crack in windshield.
      S: Suspect you're right.
      P: Number 3 engine missing.
      S: Engine found on right wing after brief search.
      P: Aircraft handles funny. (I love this one!)
      S: Aircraft warned to: straighten up, fly right, and be serious.
      P: Target radar hums.
      S: Reprogrammed target radar with lyrics.
      P: Mouse in cockpit.
      S: Cat installed.
      And the best one for last..................
      P: Noise coming from under instrument panel. Sounds like a midget pounding on something with a hammer.
      S: Took hammer away from midget
      • ^^TommyTee
        • 424
        too funny guys
        Please be aware all my posts and associated links are purley for educational purposes only ... i will not be held responsable if you use any of this material or links whatsoever its at your own risk!!
        I do not condone any illeigal use of any information contained within.
        No1 Automotive Contributor ? BOLLOX
        PEOPLE CALL YOU A TWAT !!!
        Greetingz too 0ptik and the TRUE
        Automotive RSE Crew
